- Jan 18, 2023
One thing thing that isn't discussed enough, is belt deflection. It is probably the biggest killer of belts aside from just burning it via slippage. Deflection happens in two forms. One is from improperly aligned clutches (self explanatory) , and the other is due to torque. The torque can be so great as to cause the crankshaft (aka primary clutch shaft stub) to bend as well as the secondary clutch shaft, thus pulling the two towards each other causing the belt to bend as it rotates. That causes a lot of heat due to friction (think of bending metal enough till it breaks) which leads to the belt letting go.
Sorry for the long winded post, but I felt that the information might help some understand the real benefit and purpose of double shearing the clutches.
