Accessories that draw 100 amps
NacidoenBaja
Member
Does anyone know how many amps el diablo will be able to power? I have an accessory that draws 100 amps. Will I have to run two batteries? or when I use the accessory will it stress the electrical system and damage it?
thanks for the help
thanks for the help
Holy smokes what are you powering that needs 100 amps? I would say definitely yes on two batteries. I can't quote on the alt. amperage because over time I've heard Robby say different numbers but 100 amps for one accessory is a bunch.
Well my Diablo will calling Baja home so that’s out of the question, I have a fire engine siren off an old engine I worked on and had the thought of running that rather than a horn. It’s driven by a starter motor.
Unless you are trying to run that horn without interruption, you should not have any problems.
jmpo ;)
Go and have fun!
Thanks for the information it will we tapped from time to time. I might not have a place to mount it .
